Hatch won't go down
Old Feb 8, 2011 | 10:51 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Hatch won't go down
I spent about 20min reading search posts but didn't find my issue.
When I close the hatch, it latches but the motor won't pull it down. The motor does not turn on at all. Once in awhile when I am driving around it will engage and close.
I removed everything, took it apart and put it back on the car. It worked for a day then the same issue happened.
Old Feb 8, 2011 | 01:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hatch Won’t Close — Not Good In A Submarine
If the unit raises but won’t pull down take a look at the two switches in the unit.
One is moved when the hook presses on it
The other one is a small round one with a spring near it with a tab.
It rotates as the motor operates.
Make sure both function.
The small round one can fall out.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
jrdturbo
Mar 31, 2016 02:58 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
