Passenger side running lights/blinker problems
Old Feb 11, 2011 | 03:08 AM
Justin1989's Avatar
Car: 1989 GTA
Engine: 5.7L TPI 350
Transmission: Automatic
Start my 89 firebird up after college and suddenly I have blinker problems.. Also my passenger side fog light is out, just went out as well, not sure if that's a coincidence or what.. But the passenger side running lights (front, side) are not turning on like normal. The green arrow in the dash points to passenger side at all times EXCEPT when I turn on my right (passenger) turn signal. The bulbs (for the yellow lights at least) are all good, have not checked fog light yet. Fuses appear to all be good. Also should be noted that when I signal for right hand turn (passenger) blinker and running lights turn on and remain solid. They appear to be normal brightness in contrast to driver's side running lights. It's late and cold and I have class in 9 hours. Any advice guys?
Old Feb 11, 2011 | 03:33 AM
Justin1989's Avatar
Car: 1989 GTA
Re: Passenger side running lights/blinker problems
Went out and tinkered with it. Wires leading to the flasher (right behind the flasher basically) seem somewhat bad, needed readjusting/moving around.. Probably bad wiring but it works for now. Try moving it around with your hazards on and see if it works. May this serve future people searching for this problem.
Old Feb 11, 2011 | 03:47 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
glad ya found it, wiring on my cars all tweaked as well. hit the brakes, with out any lights on, and the parking lamps, and interior lights come on.. lol
Ikes 91Z
Dec 9, 2015 03:49 PM
LittleFranks
Aug 20, 2015 03:55 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
