How do i replace battery cables? please help!
Old Feb 14, 2011 | 09:43 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
really need some fast responses since the trans am is my daily
so...how do i replace the battery cables?
Old Feb 14, 2011 | 09:46 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: How do i replce battery cables? please help!
oh! and its just the positive cable
Old Feb 14, 2011 | 10:24 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: How do i replace battery cables? please help!
Remove the negative battery cable from the battery first to avoid unwanted lightning under the car.
Then replace the positive cable.
Old Feb 14, 2011 | 11:05 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
does it just unbolt from the starter?
Old Feb 14, 2011 | 11:34 PM
AmorgetRS's Avatar
Yes, it is bolted to the starter. It is attached in a couple other places with those plastic clip things along the lower rad support and maybe some other places.
Old Feb 14, 2011 | 11:59 PM
kcb37's Avatar
I'm kinda curious why just the pos?
But like said take the neg off the bat, then the pos, then unbolt the pos from the starter. Put on in reverse order.
Unless your neg is new already I would do both. They get old and cause alot of resisitance. Really need both in good condition, wouldn't hurt to check the alt cables either.
Old Feb 15, 2011 | 03:13 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
oh..cuz my power steering pully decided to cut it..the negative one is still good
theres no cover over the bolt i have to un-do?
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
