Shift light , Launch control , VSS ?
Old Feb 18, 2011 | 06:08 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Hello Im installing a shift light with launch control in my 85 iroc that is not computer controlled , but dose have a t56 with the pigtail hanging out from the VSS . How would one go about wiring this ?. I do not know witch one to buy , so suggestions are welcome , one that will fit in a 2 1/8 gage pod . MSD 8360 dizzy with 6al with white tac wirer from box .
Old Feb 18, 2011 | 08:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Shift light , Launch control , VSS ?
Originally Posted by RocBoy
Im installing a shift light with launch control.
What do the shift light install instruction say?
Usually one wire for tacho signal and one wire for the VSS output from the computer;
which you don't have
Old Feb 18, 2011 | 08:18 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Did not buy yet , if it was just a shif light i would have no problem wiring it . Its the atvating the VSS for the launch control that I am questioning . Right now the VSS is just mounted on the trans . I do not want to buy this type of light , if I can not hook up on a Non computer controlled vehicle .Thanks
Old Feb 19, 2011 | 01:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did not buy yet , Right now the VSS is just mounted on the trans . I do not want to buy this type of light , if I can not hook up on a Non computer controlled vehicle .
You need to look at the install instructions and see what signal they require
The Raptor unit has a single wire to pickup the VSS signal that goes from ECM to speedo ; not the speed signal from VSS to ECM ( 2 wires )
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
tnrednneck
Aug 13, 2015 08:57 AM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
