aftermarket h4 headlights
Old Feb 19, 2011 | 05:55 PM
stetzz's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0 305 TBI E
I purchased a couple aftermarket h4 headlights ( http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT ). I was wondering if anybody has ever converted it to these and if there is any conversion needed. If so if you guys could possibly point me in the right direction.
Old Feb 19, 2011 | 06:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: aftermarket h4 headlights
is your friend. There's at least 26 gizbillion threads here about headlight conversions.
Old Feb 19, 2011 | 07:06 PM
Stephen's Avatar
Car: 87 GTA
I've tried those exact H4 4x6 housings in my GTA. They totally sucked & went & bought Sylvania Silverstars the next day!
They make for good housings to cut up & put real projectors in, but that is about it.
stetzz's Avatar
That would help if i knew what i was lookin for. i dont even know what to search for. I need help
Old Feb 19, 2011 | 07:07 PM
stetzz's Avatar
oh ok thanks alot bud
Old Feb 19, 2011 | 07:28 PM
Stephen's Avatar
Car: 87 GTA
Projectors like these are what you can use to mount in those housings. Some people go to junkyards & rob projectors from used cars. That is fine, if you can find some that work.
The hard part about putting projectors in a Firebird, is clearance for the flip up lights through their range of movement.
Old Feb 20, 2011 | 01:39 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you run H4 bulbs, you're going to have to re-pin the existing headlight connector.
Read this tech article:
https://www.thirdgen.org/headlightupgrade
Specifically:
https://www.thirdgen.org/tech/images/connect.gif
Old Feb 20, 2011 | 12:27 PM
stetzz's Avatar
Thanks guys!
Old Feb 20, 2011 | 12:52 PM
Stephen's Avatar
Car: 87 GTA
I forgot to put the link in for "Projectors like these.....http://www.theretrofitsource.com/pro...38b187217472d5
Old Feb 20, 2011 | 12:53 PM
Car: 1992 RS
Engine: Carbed 350
Top of the page - red bar all the way across - click search. Try "headlight Conversion", try "H4 Headlight" - it's just like any other search box.
You'll also need to make a new wiring harness for headlights and use relays - anything that draws more power than stock repalcements will melt these old wires.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
