STS help, please
Old Feb 21, 2011 | 03:36 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
STS help, please
I had installed a sequential turn signal "kit" that I bought from a member here last year. They worked fine until just before the car went away for the winter. Now when I turn on the left turn signal, it doesnt flash, as if a bulb were bad. I checked the bulbs, and the tightness of the sockets in their holders, and still nothing different. The rear will only light up the inner most bulb then it stops, even on the brakes. The right side is unaffected. I saw that the socket for the bulb in the middle was corroded and replaced it, still nothing. I thought I would see what you guys think since I went through all the possibilities I thought of.
Old Feb 23, 2011 | 06:24 AM
thetaman85's Avatar
Re: STS help, please
Anybody?
Old Feb 25, 2011 | 09:39 AM
thetaman85's Avatar
bump
Old Feb 27, 2011 | 03:23 PM
thetaman85's Avatar
Update: I have replaced the turn signal switch and it resulted in nothing different. (other than a broken in 10 pieces hazard switch)
Does anyone have any suggestions? A short possibly? Bad STS module? I am at a loss as to new ideas on this.
P.S. I forgot to add that when the headlights or markers are on all lights function normally. Only things are symptoms described above, as well as the hazards do the same thing. Right side is fine left side, only inner most bulb lights and stays lit, does not flash. No fuses are bad and I have replaced the flasher and all of the bulbs.
Old Mar 2, 2011 | 06:01 PM
thetaman85's Avatar
Any help? This thread is lonely...lol
I also had to replace the cancel cam because it too broke upon re-install. So I guess the search for a short starts now, unless someone else chimes in.
Old Mar 3, 2011 | 08:43 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sequence Of Events
Sounds like the left module went.
Is the module encapsulated or open?
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Old Mar 3, 2011 | 11:13 AM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
talk to stephen
Old Mar 3, 2011 | 02:17 PM
thetaman85's Avatar
Its enclosed, I got it from BigBadLou, from what I remember.
Old Mar 3, 2011 | 03:22 PM
NINÅ's Avatar
Transmission: 765R4
Sequence Of Events
Because it’s enclosed or encapsulated you want to see if a module is available from Lou.
Otherwise you can make one from 4 transistors.
Happy Racing!
Old Mar 3, 2011 | 10:18 PM
thetaman85's Avatar
I have Pm'd Lou about this, it may be the module and he may have a spare. I will be testing the module with my light tomorrow. I hope to find a solution to this problem one way or another.
thanks again
Old Mar 25, 2011 | 08:50 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
did you come up with a answer for your problem?
Old Mar 25, 2011 | 10:30 PM
thetaman85's Avatar
Yeah, rust in the contacts of the module, Lou cleaned it up for me and now it functions perfectly
C409
Sep 1, 2015 03:42 PM
Shinobi'sZ
Jan 9, 2010 03:47 PM
2.8RS
Apr 23, 2008 08:09 PM
KiLLJ0Y
Dec 8, 2005 07:46 PM
doc
Jan 15, 2005 04:39 PM
