Can the STS rear mounted turbo be ....
Old Jan 14, 2005 | 06:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
modified to fit our 3rg gen cars???
STS has a kit for the LT1 Camaro and another for the LS1 Camaro. Do you think that with a fab shop, the STS LT1 kit could be made to fit our cars?
Old Jan 14, 2005 | 08:53 PM
KiLLJ0Y
Guest
Posts: n/a
they are currently working on a thirdgen prototype.. several people have already volunteered.
i have a house in orem UT, its 3 miles away from STS, pretty nice guys. from what i saw, kit should be done in a month to 2 months.
the kit is basically the same, the only difference is the tube to the intake manifold, which is what they are working on
Old Jan 15, 2005 | 09:58 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Yea, I figured if you got the kit for the LS1 and LT1 cars, it should be routine to route/bend pipes a bit different to fit our 3rd gen cars. Then you open up a new marketing area.
Old Jan 15, 2005 | 04:39 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
The entire system would be fairly easy to build. I would recommend that route instead of modidying an existing kit. But if they are working on a direct fit kit, then they already have your solution.
FWIW, I have a Z24 with a home-brew remote mount turbo system and it works very well. I'm anxious to see some results on third-gen f-bodies!
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
