vats value
Old Mar 26, 2011 | 04:35 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
vats value
my key reads 2.36. even when i put key in on position. i thought someone on here years ago said the lowest chip value g.m. made was like 3. that being said i still have a no start.
Old Mar 26, 2011 | 05:55 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: vats value
VATS resisance can range between .4 to 11.8 ohms.
Your key is a #8.
Old Mar 26, 2011 | 06:34 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: vats value
ok that being said it says #8 is 2.37. will my 2.36 reading start it?
Old Mar 26, 2011 | 06:44 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: vats value
yes, there are tolerances that GM has in place, can't remember specifics, but it isn't as tight as .01 ohms of difference.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
