Water temp Gauge
Old Feb 22, 2011 | 06:02 AM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
Water temp Gauge
I have an 87 iroc been swapped from tpi to carb before i purchased. I replaced the water temp gauge on instrument cluster, just got water temp sensor, and connector. Hooked everything up to the wires i thought were the right one's ran the car gauge does not work. I followed the diagram shows yellow and black. Anyone show something different??
Old Feb 22, 2011 | 09:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Kolor Konfusion
It sounds like you used the temp sensor for the ECM.
The sender for the gage has a
green wire.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Feb 22, 2011 | 11:57 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Kolor Konfusion
Sender for the guage only has a single wire, dark green. If you got the SENSOR for the ECM that has a two ire connector on it, you got the wrong thing. You want this:
http://shop.advanceautoparts.com/web...S_575658306___
Old Feb 22, 2011 | 04:41 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Re: Kolor Konfusion
I thought the green wire was for the ecm which turned on the fan(s)? Its the sensor with the pop up button single wire isnt it? I needed both the car has an after market temp gauge.
Old Feb 22, 2011 | 04:49 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Re: Kolor Konfusion
I bought the 2 wire's from Gm dealership for the 87 iroc, I thought the one with 2 wires was for the gauge thats what the diagram calls " Coolant temp sensor" The other is called "fan switch" Its like a turkey popper it pops at set temp to turn fans on...
I am so GD. Confused Maybe i'm mis reading these diagrams
Old Feb 22, 2011 | 05:23 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Water temp Gauge
Gauge sender is in the drivers side head. Single green wire.
Old Feb 22, 2011 | 05:27 PM
Car: 1992 RS
Engine: Carbed 350
Re: Kolor Konfusion
That's why I gave you the link to the RIGHT part - to avoid confusion.
There are 3 things that are called "coolant" something ...
1) Coolant Temperature Sender - this is in driver side head, between #1 and #3 spark plug - this feeds the guage (has 1 wire connector - dark green wire)
2) Coolant Tempurature SENSOR - this is in the thermostat housing on top of the intake at front of motor - it sends reading to the computer (has two wire connector - black & yellow wires)
3) Coolant Fan Switch - Pass side head between #6 & #8 spark plug - this senses coolant temp and turns on fan (has the mushroom connector - single wire)
Now - every auto parts place is different, and they all call each one a different thing. Why? Because some computer programmer that set up all these computer applications and websites ... that is a complete idiot when it comes to car parts and couldn't find a gas pedal if his life depended on it ... programmed this stuff.
That's why YOU have to know what it is you need, and LOOK at the part at the store to verify you are getting what you want.
Old Feb 22, 2011 | 06:06 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Re: Kolor Konfusion
You are so right. Ok what i didnt know is there are 3 sensors for water temp under the hood. The way the diagram shows it, there are only 2. I have not gotten the part yet but i will get it tomorrow and get it connected. Thanks for the help
Old Feb 22, 2011 | 06:11 PM
Car: 1992 RS
Engine: Carbed 350
Re: Kolor Konfusion
No problem man - good luck!
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
