Superbrightleds.com L.E.D. Resistor help
Old Feb 27, 2011 | 12:11 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Does any one know about resistors? I wanna by some resistors from RadioShack so that I dont have to pay for shipping and wire up my spare LEDs from Superbrightleds.com. According to this page ( http://www.superbrightleds.com/cgi-b...2Fled_info.htm ) it says that the blue LED must be wired to a 470 ohm. So I looked up the 470 ohm resistor through RadioShack but the color codes are different from the little resistor that is inside the LED that I got. Can any who knows about this field help me out? Im color blind but according to my daughter, the color codes in the superbrightled resistors are red, black, black, black, and orange. Thanks guys.
Old Feb 27, 2011 | 03:52 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Superbrightleds.com L.E.D. Resistor help
That's an invalid code, but starting from the other end with orange, you have a 300 ohm resistor with a tolerance of 2%.
Check out the calculator here..
http://www.hobby-hour.com/electronic...color_code.php
Old Feb 28, 2011 | 08:04 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Resistance Is Futile
300Ω is NOT a standard value therefore should not be stocked by RadioShack.
But it’s possible for them to have surplus items which might contain unusual values.)
A part number of the part you got from the Shack would render more info.
Of course you want to adhere to the recommendation of the LED supplier.
However you said “
If you have LED BULBS the resistor is incorporated internally therefore you don’t need to add a resistor.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Elephantismo
Feb 13, 2019 12:51 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
studebaker60
Sep 7, 2015 12:36 PM
greenyone
Aug 29, 2015 11:08 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
