FUSE PROBLEM/hatch motor problem
Old Mar 5, 2011 | 05:44 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
OK my fuse for my horn and interior light and the hatch button keepls on BLOWING! well change it and nt even a day goes by and the fuse it burnt a brand new fuse!
been threw three fuses stoped there not wasting any more
also my hatch component is screwing up (again) i had to take it out and tie the trunk down with the t top strap
the hatch was jammed took it apart lifted the hatch holder thingy up and hokked her back up then it moved down so i connected the key and turned it and it didnt move up seems to be stuck i took it
plz help!!!!!!!!!!!!!!!!!!!!
thinking about gettin this from thirdgen ranch
http://thirdgenranch.com/-strse-354/...tch/Detail.bok
non moterized latch i wonder if it will work
Old Mar 9, 2011 | 07:32 AM
Hercules's Avatar
Car: Ford F-550 & '89 GTA
Engine: 7.3L Turbo D. & 5.7L TPI
Transmission: auto
Axle/Gears: stock
Re: FUSE PROBLEM/hatch motor problem
There was a post on GTA source page. Someone had made their motorized hatch into a non motorized. They had got into the back seat with trunk shut. Pulled down on the hatch and made a mark on the hatch release. Then screwed it into place so it does not move anymore. The release button still works but does not use the motor pull down anymore.
If you unplug the motor will it still burn the fuse?
Old Mar 9, 2011 | 08:42 PM
dabird07's Avatar
Car: 92 firebird
i havent tried that yet . . . .
i just recently took it out and have my t-tops straps holding it down ill try the fuse thing tomorow man and let u kno worst comes to worst imm buying that non motorized peice from thirdgen ranch
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
