Green Wire 12V
Old Mar 6, 2011 | 01:15 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Green Wire 12V
Anyone knows were this green wire goes? Gave me a shock just sitting on the firewall. It is a bare wire the picture may look a connection but I used that to cap it off. Have not traced the wire as it is all bundled in the wire loom below the brake booster. Any ideas?
Thank you
Old Mar 6, 2011 | 05:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Green Wire 12V
have a white stripe in it, or solid green?
darker green (like grass), or lighter green (like jello)?
Old Mar 6, 2011 | 06:31 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Re: Green Wire 12V
Solid green darker like grass...no stripe
Old Mar 9, 2011 | 12:25 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: Green Wire 12V
i have a solid green wire like that and mine is for my tempeture sensor. not saying thats what it is but might be a place to start
Old Mar 9, 2011 | 09:31 AM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Re: Green Wire 12V
Ok will double check that...but would that have 12V going to sensor? Already have another gauage hooked to the temp so that could be right.
Old Mar 9, 2011 | 10:45 AM
Car: 1992 RS
Engine: Carbed 350
Re: Green Wire 12V
temp sender wire should not have 12v on it
Old Mar 9, 2011 | 11:53 AM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Re: Green Wire 12V
that is what I thought so rules that out.... Any other ideas?
Old Mar 9, 2011 | 03:11 PM
Car: 1992 RS
Engine: Carbed 350
Re: Green Wire 12V
Not really - here's wiring diags you can study: http://www.austinthirdgen.org/index.php?pid=19
Might have to tear into a loom and trace that sucker down by hand.
Old Mar 9, 2011 | 04:03 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Re: Green Wire 12V
On my 88 bird i have a solid dark green wire in that location that use to go to the egr.
Old Mar 9, 2011 | 08:58 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Re: Green Wire 12V
The EGR already is connected might have to rip it out to trace were it goes...thanks
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
apie2546
Aug 8, 2015 07:12 AM
