Power to Accel Super Coil
Old Mar 8, 2011 | 06:55 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Really Hope someone can help me with this as i am stumped. I have an 87 Trans Am 350 TPI. I currently have no spark coming from the remote Accel ignition coil. It has a new distributor and i am getting 12V from the pink wire in the gray connector. When i check the terminals on coil i am reading no voltage with key in the on position. When i take the wires off the coil i am reading 12V. So it seems that there is power in the wire but when it is hooked to the coil i read 0V.
Does anyone have an ideas?
Old Mar 8, 2011 | 07:08 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Power to Accel Super Coil
that means that there is not any amps going thru the circuit. are you using a digital voltmeter. if so get a analog meter. there could be a fuse problem as well.get an analog meter and check it out.
Old Mar 8, 2011 | 07:49 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
I used a digital one. What do you mean by fuse problem? I have checked all under dash fuses and all are fine.
Old Mar 10, 2011 | 07:39 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Swap your stock coil back on and see what happens.My car eats the aftermarket coils for breakfast.Been through 2 of them and will prolly stay stock till I try a D.U.I. distributor set up.
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
Thirim
Aug 13, 2015 03:09 PM
L98GTA87
Aug 5, 2015 11:02 PM
