Fuel and Oil pressure gauge
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Hi,
Can any body tell me which cables are responsible for signal for fuel and oil pressure gauge ? What are the colors and which connectors cause i found two of them at the back of gauge panel in my 1987 Camaro (V8)
best regards
best regards
Re: Fuel and Oil pressure gauge
digging up, there are two connectors for gauge cluster, black and white, i was told that:
right connector
4th pin from right top is tacho signal
6th pin from right top is oil pressure signel
4th pin from right bottom is fuel level signal
is that correct ?
best regards
right connector
is that correct ?
best regards
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
oil pressure will have a dark green wire going to the gauge.
fuel level will be a purple wire going to the gauge.
R3500
Aug 17, 2015 12:16 PM
