Which Altenator?
Old Mar 16, 2011 | 12:07 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Which Altenator?
I need some advice guys. I got a 900 watt mono block amp in my IROC and I believe the altenator is taking a dump. So Im gonna buy a new one soon. So which altenator should I get? What is a good amp range that I should get without worring about melting my fuses? Here is the specs on my amp:
500 watts RMS x 1 at 4 ohms
900 watts RMS x 1 at 2 ohms (wire subs in parallel for a 2-ohm load)
Class D design
variable low-pass crossover (50 - 300 Hz @ 12 dB/ octave)
speaker and preamp level inputs
preamp outputs
variable bass boost (0 - 10 dB @ 40 Hz)
subsonic filter (removes inaudible extreme low frequencies for cleaner performance)
remote bass control with 19-3/4' cable
requires 4-gauge power and ground cables ( wiring and hardware not included with amplifier )
gold-plated connectors
WaynesRS
Aug 28, 2002 11:13 AM
Maximus
Jul 11, 2002 01:33 AM
Dex
Jun 7, 2002 02:21 PM
german-motorsport
Jun 24, 2001 04:27 AM
