Body Harness
Old Mar 16, 2011 | 07:20 PM
blakecharles's Avatar
Body Harness
Yo Thirdgen,
The guys in the junk yard hacked up all the factory body harnesses. I'm looking to get an EZ or painless as a replacement. The 18-21 circuit harnesses seem to have more then what I need (shaved door handles w/ alarm + after market radio). Are these good alternatives?
I'm doing a CA SMOG LEGAL LS1 w/ T56 swap btw (have the harness and PCM).
Old Mar 16, 2011 | 08:11 PM
Re: Body Harness
All are w/ GM keyed columns and pre terminated on fuse blocks... Any opinions anyone? Is anyone NOT using the factory bulkhead?
EZ wiring
http://www.ezwiring.com/wiring_harness.html
Painless (street rod version of the 18 circuit)
http://www.painlesswiring.com/webcat...rchField=10201
hotrodwires
http://www.hotrodwires.com/
Mr. Roadster 20 Circuit Wiring Harness ($150 is cheap, but lots of good reviews)
http://www.speedwaymotors.com/Mr-Roa...ess,42872.html
Rebel Wire
http://rebelwire.com/rebel-wire-prod...at=Wire%20Kits
kmjperformance 1-515-733-2890 (Universal 20 Circuit Wiring Harness Kit Hot Rod)
kmjperformancewarehouse.com
Old Mar 17, 2011 | 12:42 PM
Re: Body Harness
I called and talked to the guys at EZ wiring. Told him I was doing and LS1 swap on a 89 camaro. They checked and said the length was good. Ordered the 21 circuit (18 fused) kit. It's made for a GM column and everything is pre terminated on the fuse box. All the switches are attached and all wires a labeled every 5" or so.... Should be a breeze. I will let you know how it go's.
EZ 21
18 FUSES 21 CIRCUIT
AVAILABLE IN COLOR OR BLACK
Radio, Coil, Dome Light, Backup/Cruise, Horn, Cigarette Lighter, Fuel Pump, AC/Heat, Radio, Turn Signal, Horn, ACC, Wiper, Gauges, Hazard, Fan, Power Window, Power Door Locks, Brake, Headlights...
$202 shipped
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
