Would like to get third tail light to work
Old Mar 25, 2011 | 12:49 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I have a 89 RS,My rear third tail light won't work. I have change all bulbs, and looked at the wiring that they connect to, everything looks good. I just don't know what to do
to fix them. Any suggestions? I sure would like it to work!
Thanks for any help!
Old Mar 25, 2011 | 01:34 AM
Engine: MPFI
Re: Would like to get third tail light to work
I meant my third brake light..
Old Mar 25, 2011 | 09:52 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is this the spoiler mounted light? If so, are the contacts in the lid making good contact with the piece on the trunk top?
Old Mar 25, 2011 | 04:00 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
With the brake applied, is there 12V across the two contacts which mate to the pins on the hatch lid? If so, then your problem is in the hatch. If not, then the problem is in the wiring forward - yellow wire to the brake pedal switch.
Old Mar 25, 2011 | 06:05 PM
Engine: MPFI
Thank you, I will check that out.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
