No Fog Lights No Instrument Panel Lights - Related?
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
My fog lights dont work. The button doesent even light up. Also my instrument panel lights dont work. The dimmer switch works because i can turn on the interior lights with it. Are those 2 problems related anyway?
Engine: 5.7 L98
Re: No Fog Lights No Instrument Panel Lights - Related?
fuses are good, switch for fog lights never lights up. looks like there is a relation, im just not the best with electrical diagrams. could it be a bad fog light switch? and how would that effect the cluster lights?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Driving In London
The bulb for lighting the button and the instrument lamps not lighting might be an illumination dimmer problem.
You said “The dimmer switch works because i can turn on the interior lights with it.”, however the interior lights and dash illumination are controlled by different parts of the “dimmer switch”.
To find out, make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe both sides of the INST LPS fuse.
If there is no power there check for power on the orange wire at the headlight switch.
Then check for power on the dark green wire at the headlight switch.
Make sure there’s power on both wires.
Fog Lights:
Probe both sides of the FOG LPS fuse.
Is there power on both sides?
If there is, make sure the headlight switch is in the Lo-Beam position, then probe the yellow wire at the fog light switch.
Make sure there’s power there.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Fog Lights:
Happy Racing!
Ghettobird52
Jul 5, 2024 11:18 PM
