No Taillights, Fog Lights, Cluster Lights, Marker Lights, no highbeams
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I have no tail lights, no fog lights (the switch dont even light up), no marker lights, no cluster lights (although warning indicators work, just the backlighting dont)
seems like the common thing on all these wiring diagrams is the headlight switch. but the low beam headlights work.
where should i start?
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: No Taillights, Fog Lights, Cluster Lights, Marker Lights, no highbeams
have tinkered around the radio compartment lately, or replaced the radio?
Engine: 5.7 L98
i just bought the car, but it does have a aftermarket radio in it. but its a old crappy one so it may have been in there a while. but 1 thing i can tell you is the radio dont turn off unless i take the face off - even with the car off
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Engine: 5.7 L98
turned out to be the headlight switch. go figure...
