Starter Wire(little spade connector) Wont Crank
Basicly when i turn my key with the clutch safety switch engaged it just dims the lights when i turn the key. No noise from the starter. There is a little black wire that turns to yellow with a spade connector that plugs into the starter(mini starter). Im pretty sure the rest of the starter is wired right. The purple on the solenoid side. Then the 2 orange fused wires plus the + batter cable on the other side. Then that spade connector has a spot to plug into on the starter. The only weird thing is that the spade connector is constant 12v. I dont know if thats right? I can here a relay click on the DS by the C100 bulkhead connector. The car is an 86 trans am with a 88 camaro engine harness.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Starter Wire(little spade connector) Wont Crank
no clue what that other wire with the spade connecter is, but are you sure the battery isnt too low to spin the starter? also check the purple wire and make sure isnt not grounded out somewhere.
I can jump the 2 terminals on the start and get it to crank over. Soothe battery has juice. I even had it On trickle charge all night. I guess i will attempt to test that purple wire for 12v. Should it Only have 12v when key is turned to start? Also i guess I will add that the temp gage goes up to being pegged out when I turn the key it's not immediate but just sweeps over in about kinda moderately fast.
Car: 91 Camaro RS
yea, the purple wire only gets juice when the key is in the start position. if it grounds out, it could cause the issues youre having. i managed to pinch mine between the head and block when doing a head gasket change in the car once. caused everything to dim when turning the key to start like it was a dead battery, with no sounds from the starter.
Originally Posted by dabomb6608
I guess i will attempt to test that purple wire for 12v....
After testing the terminal with the purple wire(still attached) it shows that it definitely isn't getting full power. I tested the yellow wires inside the car at both the clutch safety switch and the the connector for the park/neutral switch and it has about 10-11volts. But for whatever reason the purple wire isn't getting that much at the starter. It's also a new mini starter and when I installed it I had to put a new ring connector on the purple wire so there shouldn't be any corrosion.
After testing the terminal with the purple wire(still attached) it shows that it definitely isn't getting full power....
Car: 91 Camaro RS
purple wire should get a full 12v. it youre only getting 10v either your battery is low, or you have a partial ground on the wire. check the purple wire at the bulkhead connector and see if its getting 12v there. if it is, then you def have a partial ground.
The purple wire is getting right around 10volts. So does that mean I got a crap starter?
The battery I was using was low. Both the battery and the purple wire had 10v. But even when I put my battery from my truck(starts easily definitely not dead) it still doesn't crank.
eightsixseven
08-14-2015 03:09 PM
