Steering column stuff
Car: 91 RS
Engine: 305 TBI
Transmission: 700R4 shift kit vette servo
Axle/Gears: 3.73 Eaton Posi
Ok so I took the ignition switch out and yea what a PITA!!!! Anyways, what is the rod for that goes into the ignition switch from the column???? I know the other one is a dimmer one but is it possible to just not reinsert that other rod or does it serve some real purpose???
I have searched on here and I haven't read anywhere about anyone just leaving this rod out....
By the way this car is pretty much a track car so im not to concerned with it being stolen....
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Steering column stuff
Think that maybe that rod is what makes a physical connection from the key cylinder to the actual ignition switch to start the car ?
wigmobile
Feb 26, 2025 02:56 PM
