wireing harnesses the same?
Old Apr 5, 2011 | 11:37 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
My 89iroc w/350tpi has some cut up areas in it.One place is the radiator fans.One must have been wired in direct,cause when the key is on the drivers side one runs.Plus mices chewed up the wires that go to the maf sencer.I've spiced it together while I'm working on bigger things.Eventually I want the engine bay back to a clean stock set up.The smog pump was removed and I think the alarm system may have been disabled.The stering wheel dosn't have the horn hooked up at all now.I'm wanting to know if a 305 wireing harness from the same year would have all the same leads on them or dose it have to be an 89 iroc 350tpi w/air and so on? Any coments on fixes to my list of problems would be apresheated.
Old Apr 6, 2011 | 12:39 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wireing harnesses the same?
A TPI is a TPI ; regardless of engine size
Obviously a TBI harness will be different
Old Apr 6, 2011 | 11:34 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
just checking,how about the year model? Say,86-89 go together and 90-92?
Old Apr 7, 2011 | 05:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
90 - 92 ( SD ) requires a different computer and some other changes
Old Apr 8, 2011 | 03:37 PM
Pocket's Avatar
Car: 91 Trans Am
Breakdown for TPIs
85 is it's own deal
86-87 are similar and use a 165 ECM. A few changes and they'll interchange directly
88's are similar to 86-87 but a few more differences that Id put them in their own group. Also 165 ECM
89's are different from all other years. Quite a few mods to put them in something else. 165 ECM again. Closest pinout to 90-92 cars of any other year. Easiest year for a SD swap
90-92 are identical, 730 ECM
For TPI harnesses, there is no difference between 305 to 350. The long block, injectors and PROM changed. Everything else stayed the same
Old Apr 9, 2011 | 02:41 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
what dose SD stand for?
Old Apr 10, 2011 | 05:06 PM
Pocket's Avatar
Car: 91 Trans Am
Speed density aka the 90-92 TPIs
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
