90-92 electric cluster
Old Apr 3, 2011 | 01:42 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I just gt my new tom me 90 IROC-Z and went to drive it tonight and had no cluster lights at all. The heater/ a/c lighs come on and dim, but not the cluster. I have searched for over an hour now and my eyes are going bonkers. Head lights come on along with tail lights.
I took the cluster out checked all the bulbs all good. Checked all fuses all good. Any help would be much appreciated. Thanks in advance.
Old Apr 3, 2011 | 09:27 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 90-92 electric cluster
head light switch
Old Apr 5, 2011 | 02:06 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
So I replaced the head light switch and that was not the problem. Could it be because a previous owner took out the stock air bag wheel and put in an aftermarket momo one? It's really weird my heater controls light up and dim with the switch just not the cluster is has no lights at all.
Old Apr 5, 2011 | 02:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Has nothing to do with steering wheel. I'd pull the cluster out and see if the PO tried to put in LEDs or something - LEDs will not operate on a dimmer switch.
Old Apr 5, 2011 | 04:13 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
No the cluster has all of the right bulbs in it and I cant see where anyone has mucked with it.
Old Apr 7, 2011 | 10:16 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Anyone? I am really stumped here!
Old Apr 10, 2011 | 04:42 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
TTT
Old Apr 10, 2011 | 05:25 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
bad circuit on the back of the cluster?(i have no clue how it goes bad or if im getting jerked around by my mechanic) my speedo doesnt work and he says its the thing on the back of the cluster that is like thin plastic with the circuittry running through it (i also have the same but reverse problem you have,,,dash lights work but no heat ctrls or radio ctrl lights he said its that circuit thing dunno sounds fishy to me though
Old Apr 10, 2011 | 09:05 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
I don't know if it will help you out at all, but I pulled out my cluster and took a small flat screw driver and pryed up on all the conectors that the cluster sits on. I now have dash lights.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
