No high beams
Old Apr 7, 2011 | 12:08 PM
Murraydpsr90's Avatar
Car: 1990 camaro rs
Engine: 5.0
No high beams
High beams don't work have the steering wheel dropped and see that the bar is loose how do I get to it to adjust it
Old Apr 7, 2011 | 12:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No high beams
You don't adjust the bar (rod), you adjust the switch at the base of the column. Don't need to have the column dropped. I'd start by putting column back up, then just adjusting the switch at the base of the column.
If you have tilt wheel, set the tilt where you drive - you can never get the high beams adjusted where it works at all ranges of the tilt wheel, so set tilt wheel at driving position first, then adjust switch.
Old Apr 7, 2011 | 12:41 PM
Car: 1990 camaro rs
Engine: 5.0
Re: No high beams
Easier to get to with steering wheel dropped I'll see if they work once the car is on
Old Apr 7, 2011 | 12:47 PM
Car: 1990 camaro rs
Engine: 5.0
Re: No high beams
Works like a champ except I have a bulb out figures. I couldn't see the screw until I saw a top view. I had to adjust it all the way up 20 years of this car being drivin will do thanks for your help greatly appreciated
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
