hatch motor problem
Old Apr 10, 2011 | 09:10 PM
blkroc's Avatar
Car: 88 IROC, 65 GTO, 78 Firebird
Engine: 5.7 TPI, 440ci, 462ci
Transmission: 700r4, th350, 5 spd OD tranny
Axle/Gears: 2:73, 3:55, 3:42
hatch motor problem
Yesterday a friend pushed my hatch down too far. (overriding the pulldown feature) Now the hatch lock is stuck down and I can't get it back up to grab the hatch. I've tried everything I can think of but nothing works. Any suggestions?
Old Apr 10, 2011 | 09:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: hatch motor problem
Yeah - never let anyone close your rear hatch.
Try removing the hatch extend relay, and plugging it back in - it's behind the rear panel on the driver side - it'll be covered in black tape - little square thing.
Old Apr 13, 2011 | 02:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Here is what happend. The striker-sensing switch was pressed starting the down cycle, yet the latch did not catch on the hatch hook. The solution is you'll need to reiset the pull-down unit. You do so by reaching in and pressing and holding down the striker-sensing switch. The switch is located in front of the latch and is attached to the latch assy with a single hex-head screw. Once the pull-down unit has finished the down cycdle you'll hear a CLICK which is the reversing swtich being tripped to end the down cycle. Release the switch and the pull-down motor should power the latch assy all the way up, ending again with a CLICK as the reversing switch again trips ending the up cycle.
Lon Salgren
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
