O2 ground
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
O2 ground
1987 Firebird 350 tpi.
Where is the O2 sensor ground wire located and what color is it?
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: O2 ground
As Apeiron said, there is no ground wire. 87 TPI uses a single wire O2 sensor, with a single wire connector, it grounds out through the block. If you have to buy a replacement O2 sensor, make sure you get one with only one wire.
