Adding a hatch relase switch (92 or late 91)
Old Apr 16, 2011 | 04:26 PM
ClassicCarLover's Avatar
Hello!
Today I added a hatch release switch to my late 1991 Firebird Trans Am. (hatch mechanics assembly with the plastic part, wich should open by switch without adding a solenoid as far as I know up to now)
So well, after attaching the relais behind the passenger side panel, switch has functionality!:
First it seems to open the hatch, but doesnt release it really, then it pulls the hatch back down.
What is going wrong? Why doesn't it release the hatch?
Thank you so much for help and answer!
Old Apr 16, 2011 | 05:00 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Adding a hatch relase switch (92 or late 91)
There is a "ramp"that needs to be in the back of the hatch pull down that unlatches the hatch after the motor brings it up.
http://www.top-downsolutions.com/lat...ody-p-152.html
I just made my own.
Old Apr 16, 2011 | 05:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sounds to me like your hatch struts are not strong enough to open the hatch after the mechanism let's go, thus the hatch is still making weight on the switch and so the motor reverses, grabs it, and pulls it back down.
Old Apr 16, 2011 | 05:12 PM
chevydrvr's Avatar
Nope, that's not it. I thought that's how mine was. I'm guessing that if the car didn't come with the option from the factory, then they left out the "ramp" I was talking about.
Old Apr 16, 2011 | 05:16 PM
I just made my own.
Thank you for your answer!
Do you have a picture of this "ramp" or do you know where I can get such one?
Thank you so much!
Old Apr 16, 2011 | 05:28 PM
chevydrvr's Avatar
They are in that link I posted. I don't have any pics of the one I made though. I basically screwed a piece of bent metal to the inside back of the pull down housing at an angle.
Old Apr 16, 2011 | 05:33 PM
Car: 1992 RS
Engine: Carbed 350
Depends on which motor assembly he has as to whether it has that "ramp" piece - there are at least 2 motor assemblies that I know of.
Before you rigged in the release switch and everything - when you used the key, would the hatch raise up on it's own when opened? If not, you need new struts.
Old Apr 18, 2011 | 01:37 PM
Sorry, which one exactly do you mean? "Used lift rod"?
Thank you!
Old Apr 18, 2011 | 03:32 PM
chevydrvr's Avatar
No, the picture of the piece is on the right side. Where it says Latch Release Block...to the right of that.
Old Apr 18, 2011 | 04:26 PM
Brock Lee's Avatar
Car: 1991 Firebird Formula
Here is a question I have (seeing you got this far). Was the wiring in the car between the dash and rear and you just added the switch components? Or did you have to add the wiring harness as well?
Old Apr 19, 2011 | 07:48 AM
I didn't have to add wiring harness! As I read in this topic, this is already added (must be since 86 or so):
https://www.thirdgen.org/hatch
As my Trans Am is a LATE 1991, it has the plastic part hatch release assembly and doesn't need a solenoid (as it was needed until 91).
Old Apr 19, 2011 | 07:51 AM
Sorry that I didn't see that... thank you so much! I think that's exactly what I was looking for!
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
