HELP HELP HELP!!! pulling my hair out! on 91-92 taillight conversion
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
does anyone have a wiring diagram , to convert a 91-92- TA taillight into a 1985 ta i have the 85 service manuel , i have the wiring harness for the 91-92 taillights with them has anyone done this to theres?? , what do i have to intergrate to get these lights to work
a visual diagram would be super!! maybe make it a sticky
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hair Today, Gone Tomorrow
If no one has a diagram you can use a 12 volt fused source to probe which wire illuminates which bulb.
Just connect ground to ground (black wires in most cases) then using the + wire from the supply, touch the unknown wires.
When the bulb illuminates, attach a label to the wire.
As far as the car you’re working on, if there is no taillight assembly on it at this time, you can find out what wires illuminate what bulb by using a voltmeter or clip on lamp then label those wires.
Happy Racing!
Don’t Ask Me Why I Don’t Get Dizzy After Going In 400 Circles
Happy Racing!
