Convenience Center
Old May 4, 2011 | 06:34 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Convenience Center
Had a problem with the Fasten Seat belt light coming on while driving every so often. It is the usual problem that I see a lot of people have from the posts I have read. Go over a bump the light comes on, go over another bump the light goes off. I decided to try and fix this but made things worse (should have just cut the yellow wire). The seatbelt buzzer hasn't worked since I had the car but that didn't bother me. I checked the seatbelt wiring and that works, short when seatbelt not connected, open when connected. I metered this from the convenience center. I removed the convenience center and opened it up. I touched up the solder joints but when I put it back in the fasten seatbelt light stays on all the time.
I checked on ebay but couldn't see any for sale. Would anyone have a circuit diagram of the convenience center so I can follow the seatbelt circuitry. The" lights on" part of the circuit works okay. I presume that the car doesn't have to be started for the seatbelt light to go off. I didn't check this.
Any help appriecated,
Thanks.
Old May 4, 2011 | 02:54 PM
gholian's Avatar
Engine: 2.8 V6
Re: Convenience Center
I had a look round and can find a few GM Chime/buzzer modules. They have the same 7 pin connector as the one I have. I have an 82 Firebird and wonder will another GM Chime/buzzer module fit it. The number on the front of the module in my car is 1403432. I have seen two with the part number 15969639 and one with the part number 22535998but have no way of knowing if these are compatable.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
