All I did was which the TPS Sensor... and now this >=(
Old May 7, 2011 | 05:09 PM
Irocz_89's Avatar
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
And then the car idles at 3,000-3,500 rpm??? What the hell... All I was trying to do was figure out why it has a high idle at start up? Maybe around 2,000rpm then goes down. So I figured that it might be... The TPS Sensor. So right when I replace it.
The car sets a Check Engine and revs to 3,500 rpm and will not go down...???
Please help. This is a 1989 Camaro 305 TPI VIN F (HO) 700R4.
Anyone?
Old May 7, 2011 | 06:56 PM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
Re: All I did was which the TPS Sensor... and now this >=(
The TPS is adjustable, you have to use a digital voltage meter and physically turn the sensor to the correct position.
Here follow these instructions and see if this fixes your problem.
https://www.thirdgen.org/tpimod2
Old May 8, 2011 | 05:27 PM
Irocz_89's Avatar
Thanks. Figured it out and now it idles fine.
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
