Removed headlight knob now no interior lights or sound?
Old 05-07-2011, 10:32 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Removed headlight **** now no interior lights or sound?
Today I remvoved my cluster to fix the tach, and after I put it all back together, the lights don't work. The exterior lights come on as they should, but the interior lights won't come on. THe overhead dome light comes on when i turn the **** as usual though. Also, there is no sound if I leave the lights on. What did I mess up?
Old 05-07-2011, 11:51 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: Removed headlight **** now no interior lights or sound?
Just guessing here because i am no expert. If 2 separate systems fail at once I would suspect you pulled (or didn't reconnect) a ground loose.
I hope this helped.
Old 05-08-2011, 08:20 AM
chevydrvr's Avatar
I may have done that, are there any fuses that I could have blown?
Old 05-08-2011, 03:50 PM
Krik's Avatar
Engine: 5.7 TPI
I don't know. I have removed my dash and reinstalled it twice. I never had a problem like this.
Old 05-09-2011, 10:38 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
"Int lights" fuse in the fuse panel. Just check all the fuses with your 12v test light to be sure. Do you think you may have broken the rheostat on your HL switch?
Old 05-09-2011, 11:50 AM
chevydrvr's Avatar
I thought I posted it here, but it didn't show up. I found out yesterday that I blew a fuse. I wouldn't have thought that the dash lights and marker lights are on a seperate circuit. The interior dash lights are connected to the driving lights, not the headlights.
BRoss99
12-07-2020 06:50 PM
Vintageracer
01-10-2020 05:33 PM
The_Phoenix
02-04-2016 07:10 AM
Omega
08-10-2015 12:46 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Removed headlight knob now no interior lights or sound?
