Not good with electrical,question on wire spark
Old May 14, 2011 | 08:39 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Hooking up my CB to my radio and the power for the radio coming from the power source knocked up against my plastic shifter **** and sparked. The interior lights and the radio now wont work. Everything else does. DOes this mean i blew a fuse? Should i reset the battery? And if it was a fuse,which fuse is it? Thanks
Old May 14, 2011 | 10:13 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: Not good with electrical,question on wire spark
i would check them all but i believe there is an interior fuse...
Old May 16, 2011 | 04:02 PM
bump
Old May 16, 2011 | 04:10 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think the interior lights are on the courtesy fuse. There is no need to reset anything. The interior lights have nothing to do with the ECM. Even if your car had a BCM controlling the lights, it would function normally once the fuse is replaced.
Old May 20, 2011 | 12:28 AM
Oh okay thanks for the info! Not to sound completely idiotic but..where is this fuse located? Haha. what number and what does it say next to it? Im sorry but fuses and wires just confuse the crap out of me unless it has to do with Subwoofers and speakers
Old May 20, 2011 | 07:08 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The under dash fuse panel is located under the dash between the steering column and the driver's door. There should be a removable cover over it. The fuse would say CTSY or may just say INT. Use a 12v test light and test all of the fuses. The fuse that has power at one side and none at the other is the blown one.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
