85 TPI into 80 camaro
Old May 15, 2011 | 03:13 AM
wayner's Avatar
Car: 1980 camaro, 1985 k20, 1988 TA GTA,
Engine: GTA 350 TPI, K20 and camar-carb 350
Transmission: GTA-swaped 5 speed,auto k20 &camaro
Axle/Gears: 9 bolt GTA disc rear
ok i recently picked up a 305 TPI went throught it and its amazing and i only paided 125 it came with a cut up harness so i went out got another harness (the orginal has the seprate burn off mod so i got another the same) uncut just the engine side to the computer now my question would be is how to power the tpi harness i know there is a 12v hot and possibly a 5v reference the other thing is i would like to use the orginal steering colume thats in the 1980 and not have to switch that to a 85 colume but by doing so would that cause problems? most everything else i have figured out but powering the ecu.
Old May 15, 2011 | 05:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 85 TPI into 80 camaro
Only need to supply 12V and switched 12V to the ECM as well as the feed to coil from stock key.
No need to touch column
Coil (Ign ) feed is also switched power to ECM
Need 85 TPI ECM wiring diagram for correct power hook ups
Old May 16, 2011 | 08:22 PM
wayner's Avatar
ok i did find a wiring digram and i see that the ecu gets 12v power already from the battery so that should be covered as for the coil power i could just run excesting to the tpi disturber would i be on the right track for this? also here is the wiring digram from chevythunder.com
Old May 17, 2011 | 08:09 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
From the Factory, the TPI ECM gets power though a connector under the dash, close to the ECM. It's C207(IIRC). The power comes to that connector from the fuse panel. You 80 fuse panel will have fuse protected Batt+ and Ignition power sources that you can use for this. Your 80 also uses very close to the same dist, I even think the BATT connectors at the dist cap are the same.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
The_Phoenix
Sep 3, 2015 10:56 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
