Positive Battery Wire - Melted
Old May 16, 2011 | 11:52 AM
C.Cannon's Avatar
Car: 1989 IROC-Z Hardtop
Engine: L98 w/SLP Performance Package
Axle/Gears: Borg-warner 9 bolt
In my ongoing adventures of restoring an '89 IROC-Z, I have found the positive battery wire has come into contact with the header at one time or another. The insulation is melted flat, so I'll have to purchase and run a new wire to the starter.
My question, is there supposed to be some kind of a hold down for the wire just to the front of the header? I see two holes, one slightly larger than the other in that area. In the meantime I will ziptie the wire down.
Thanks.
Old May 16, 2011 | 01:34 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: Positive Battery Wire - Melted
Thanks.
no there is no hold down how ever you could add one i believe auto zone carry's some that screw down
Old May 16, 2011 | 08:49 PM
Pocket's Avatar
Car: 91 Trans Am
There is no hold down until the frame rail. Thats just a piece of tin coated with rubber, not exactly secure
Old May 17, 2011 | 08:19 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Most GM V8s have a tie down connected to the pass side motor mount that routes the starter Batt wire away from the exhaust. My 87 IROC has this from the factory, or maybe I added it and don't remember, that's also possible.
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
