12 volt constant in trunk hatch light?
Old May 16, 2011 | 08:33 PM
Mancha87's Avatar
Car: 1986 IROC-Z28
Engine: TPI 305 Bone Stock
Axle/Gears: Posi-Trac
I am installing some digi-tails and I need a 12 volt constant it says I should use the one in the fuse box but I really don't understand how to wire into the fuse box.
So I noticed that my trunk hatch light had an orange wire running to it and I was wondering if anyone knew if that had a 12 volt constant. IT does not turn on everytime I open the door or anything like that it has a little switch that turns it off and on.
Also how do I connect a T-TAP? DO I need to splice the wires? or do I just close it into the wire? I'm new to wiring and I want to do this right.
Any and all help is appreciated, thanks!
Old May 17, 2011 | 08:12 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 12 volt constant in trunk hatch light?
The cargo light is 12v constant from the courtesy circuit. T-taps simply close around the wire. If you look closely, you can see the little teeth that cut through the insulation, into the wire.
Old May 17, 2011 | 11:59 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
eightsixseven
Dec 16, 2024 01:50 PM
bamaboy0323
Sep 3, 2015 06:07 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
