86 z28 no motor can i still test the starter?
Old May 17, 2011 | 12:04 PM
blk86z28's Avatar
hey just wondering my car has no motor but if i connect the starter wires and B+ to it then use a jumper cable from the housing of the starter to a good ground the electrical in the car and the starter should work when i turn the key just like if the motor was there correct? thanks ps im just trying to ensure the starter will crank because sometimes i have an issue with it possibly VATS so if i can fix it or bypass it before i drop the motor in its one more thing off the list .
Old May 18, 2011 | 05:24 PM
blk86z28's Avatar
Re: 86 z28 no motor can i still test the starter?
can anybody help me out please! i cant drop my motor in yet so in the mean time i dont want to waste time! any answers will be greatly apreciated! thanks
Old May 18, 2011 | 09:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Sure - batt pos to large termional, a good ground to batt neg, and another batt pos to smaller terminal. Or, since the starter is out of the car, can have it tested for free about any auto parts store.
Old May 18, 2011 | 09:23 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
the test method you plan to use will work fine-just
have someone hold the starter when you test it or place
it on some cardboard or something so the wires don't
short out when the starter "kicks"
BTW no VATS on '86s-IIRC,VATS came out on the '89s
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
milk
Aug 10, 2015 06:26 PM
