Horn Does not work and window problem
Old May 20, 2011 | 11:21 AM
CamaroLover123's Avatar
Engine: V-6
hello all I have a 91 camaro rs and the horn does not work at all. There is a plug that is not plugged in underneith the hood in the right hand corner. Iam not sure if that maybe the solution and also the previous owner dented the passanger door and now the window does not go down the right way. If anyone could help much aprricated
thank you
Old May 20, 2011 | 11:29 AM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
Re: Horn Does not work and window problem
what do you mean by "right hand corner" ? the driver side of the car or passenger. and i have plugs unplugged as well, my horn never worked, i doubt that plug is ur problem though, this is why, i swapped my camaro steering wheel for an aftermarket one, so i deleted all of the air bag crap, when my steering wheel was off and i was in my column i found that the plastic part that my horn wire clips to (in the column not on the wheel) was cracked and no longer holds the wire in place. i pushed it in place and did what i could to make it stay, and for a few months i had a perfect working horn, than one day i got cut off and, No Horn. so im guessing its that damn wire again
Old May 20, 2011 | 11:32 AM
Car: 1989 IROC Z
as for the window, im not sure. im sure theres people on here that know all about it though
Old May 20, 2011 | 01:44 PM
Engine: V-6
Thank you for the reply how do you post photos on here?
Engine: V-6
I will take a photo of the dent and the hood
Old May 20, 2011 | 10:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If door dented far enough in the right spot, maybe a bent window track - have to take door panel off to see.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
stalkier
Aug 13, 2015 12:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
