replacing wiring harness, need help!
Old May 20, 2011 | 02:24 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Hey guys, so I pulled out my very tired and worn out 350TPI engine from my '91Z and the wiring harness was mickey moused, black taped, and hacked into all over the place... not to mention many connectors fell apart as I tried to unplug them. For one example they tapped into and used the hot wire on the coil to power both radiator fans and daytime running lights, real nightmare.
So I purchased a pull-out wiring harness from Hawks and some things are not plugging in or I'm out in left field. I am thinking either too many things have been changed and swapped out on my 91Z or somehow I've got the wrong wiring harness. Now let me say I've found a home for almost every connector, but I need your guys help to finish this off so I can bring this new 383TPI to life!
First off is the loom of wires that head down to the starter, the ringed terminals on the red wires go to the starter, the black wire to the relay, there is a blue wire that goes to a sensor on the bottom of the block (had to extend this wire because I relocated the sensor the the drivers side due to Hooker LT headers). Now I've got a grey wire that is cut off, where does this wire belong? I am assuming it belongs to a single wire sensor on the passenger side head which is a 'cooling fan switch', is this correct?
(insert picture here)
I'm going to take a few pics, then return and attach them to this thread... so give me a bit of time, camera battery is charging!
Old May 20, 2011 | 02:26 PM
Brisk's Avatar
Re: replacing wiring harness, need help!
Secondly I have a couple plugs that do not seem to have a home, or more likely, I can't remember where they are supposed to go... One is coming out of the main wiring harness right behind the passenger side head, and another right behind the drivers side head. Where do they belong?
passenger side;
(insert pictures here)
drivers side;
(and here)
Old May 20, 2011 | 02:29 PM
Brisk's Avatar
and hopefully lastly, I have a sensor on the back and bottom side of the plenum that needs to be plugged in however I can't find the wires and plugin that it supposed to go to it.. where does it come out of the wiring harness or where should it be found?
Sorry for all the q's guys, I'm not a mechanic but I can stumble along and figure most things out, sometimes with a little bit of help!
Here is a pic;
(insert pic here)
EDIT: I just realized I won't be able to attach images for a couple days... so give me some patience guys
Old May 20, 2011 | 03:15 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
i also need help, but mines a 88 Camaro RS
Old May 20, 2011 | 10:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
wiring diags help? http://www.austinthirdgen.org/index.php?pid=19
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
