Two different types of Rear Hatch pull down units
Old May 22, 2011 | 10:39 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
OK, I know there are two different hatch pull down units. I have the one that is NOT meant to be open with the dash switch. has anyone swapped over to one that can be opened with a pull down switch? Also, does anyone know of a website with good info on these two types?
Old May 22, 2011 | 11:19 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Two different types of Rear Hatch pull down units
bump
Old May 23, 2011 | 04:28 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
There's info on here somewhere. Or you can google and find instructions. I think all you need is the solenoid operated release that simply(?) bolts to the pull down unit. A relay that goes under the dash somewhere and the switch. You can buy the dash unit with the switch and the wiring should all be in place. The connector for the switch is covered and tucked in behind the switch panel. You can buy all the parts at a junk yard or Top-DownSolutions.com has them.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
