Here Are Power Antenna Relay Part#'s
Old May 26, 2011 | 04:47 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
When I finally found out my power antenna relay was the cause of my antenna problems I searched and couldn't find the part# for it on the board so here they are if it helps anyone in the future:
GM Part# (from my 1986 Camaro) - 10028531
Cross references with these other manufacturers:
Airtex/Wells: 1R1459
Standard Motor Products: RY603
BWD Automotive: R3124
Autozone: 20118 (Alternate# 41-5603)
Also, the bracket with the relay on it behind the dash is held in with two 7mm bolts. A bit of a pita to remove but a 1/4" ratchet with a universal gets it done quick enough.
Attached Thumbnails Here Are Power Antenna Relay Part#'s-relay1.jpg   Here Are Power Antenna Relay Part#'s-relay2.jpg
Old May 26, 2011 | 05:11 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Here Are Power Antenna Relay Part#'s
how much does it cost?
Old May 26, 2011 | 05:15 PM
ryn28's Avatar
Engine: Chevy ZZ4
Autozone's price was $23.89 out the door. Price varied slightly on eBay but about the same.
Old May 26, 2011 | 10:03 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
What kind of problems were you having with your power antenna?
The reason I ask is because I have an aftermarket head unit in my IROC and when I try to use the tuner to get radio I can't even get one station, and when I do it is barely audible!
Old May 27, 2011 | 06:53 AM
ryn28's Avatar
Engine: Chevy ZZ4
My antenna going up and down was working intermittently until it just stopped. I have an aftermarket radio also and I can tell you 100% the relay is not your problem.
It sounds like you have a connection issue someplace. The cable that provides the signal from the antenna itself to the radio is a thick black cable which connects directly behind the radio and runs to the antenna mast housing where it is held on with two screws. You will get signal with it connected regardless if the power parts of the antenna are disconnected as long as the mast is up.
First I'd pull the radio and see if the antenna cable has pulled out the back of the unit. This would be my first guess. Possibly it wasn't put all the way in when the radio was installed or fit too loosely and fell out. If that's the case slightly bend up the two side tab things on the connector to make it fit a little tighter and plug it back in (it will make sense when you're looking at the plug)
If that checks out I'd pull the front passenger wheel, remove the wheel well trim and look inside at the antenna and make sure the antenna is attached to the mast (which it should be unless someone was in there messing with it)
Last I'd trace the cable from the radio to the antenna to see if it has been broken somehow (that would be odd but people do crazy things so you never know)
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
