replaced fuse now won't start
Old Jun 1, 2011 | 03:26 PM
rscamaro90's Avatar
Car: 90 camaro rs
The 15amp acc. fuse blew 3 days ago when I took it to the mechanic about the overheating/losing coolant. I picked it up today got it to the house and let it sit for about 2hrs. Went to crank it up my security light comes on, along with ses and seatbelt,fuel pump primes, no click or nothing. I cleaned my batt. term. cause there was some corrosion but still nothing. The last time this happened it was the ignition switch. I'm gonna do a search and see how to test that switch.
Old Jun 1, 2011 | 03:57 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: replaced fuse now won't start
id get a test light and check all the fuses. if theyre all good it could be something more complicated. but might as well check the easy things first. does the car not turn over at all?
Old Jun 1, 2011 | 05:23 PM
rscamaro90's Avatar
Car: 90 camaro rs
It was a false alarm, sorry. Sometimes it takes a while for the starter to kick in. The negative on batt. is a little stripped out and it is just loose enough to where every now and then it it will kill everything. Sorry again.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
