heated O2 sensor?
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
heated O2 sensor?
I have a 1985 firebird with a brand new GM 350 engine, shorty headers, and the stock quadrajet carburetor. All of the EGR stuff has been removed, except the charcoal canister. I have been thinking about my oxygen sensor, and whether it's worth replacing. I currently am set up for the one wire sensor. One wire sensor-20 bucks. 3 wire heated o2 sensor- 50+ bucks ,(90 bucks for a nice looking wire and connector setup for the one-three wire conversion) I have heard the headers do not keep the sensor hot enough to send a proper signal.
Also, do the sensors ground themselves through the threads? Would i ever have to worry about a bad ground when running headers?
My main concern is whether the oxygen sensor is worth replacing, and if so, is it worth getting the three wire conversion?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: heated O2 sensor?
I prefer the heated 02s. I had a new o2 in my '88 iroc w/ hooker shorties normally getting 17-18 mpg then added the heated o2 design and the mileage did actually go up a bit the best I recall was 19mpg that's city/hey mixed...... 5.7 T-5 and 3.27 gears and 245/50/16s the car idled much smoother. was very happy with that car til it got hit
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Problem arises with long tube headers that have sensor mounted at collector end ;
the sensor is too far back from the exhaust port and cools off when the car idles putting the engine back to open loop tune
They don't last forever so a new one ( of your choice ) is a good investment
That would definitely make sense. The oxygen sensor is only like 3 inches further from the exhaust port. I can't imagine the temperature difference being too great. Long tubes would put the sensor pretty far away. Well thank you for your response, I would hate to waste the money on a heated sensor at this point when a one wire sensor is less than half the price.
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I have read that it will speed up how long it takes to heat up the sensor. I know I have to wait at least 5 minutes to get my sensor hot enough. It runs kinda weird (some hesitation) when cold. Is there a conversion kit or something like that for this? I wanted to get a 3-wire but saw that the connector was different.
Car: 82 Z28
Transmission: T400
3 wire (heated ) O2 has a power wire and a ground; as well as the sensor wire.
All you have to do is supply a switched 12V to the heater , a ground somewhere and reconnect the O2 sensor wire using connectors
If you want it to look like stock then need something like this
http://tpiparts.net/inc/sdetail/2167
http://tpiparts.net/inc/sdetail/15837
Hmmmm...that's kind of pricey for what it is. I guess all you have to do really then is just cut off the connector and route each wire yourself if you don't want to pay the extra $26 for the adapter.
Car: 82 Z28
Transmission: T400
That's what I was thinking. I'd cut off the plug from the sensor I have now, solder that on to the new one, put heat shrink tube around it. Then I'd just ground one wire to the body and find a key-on hot wire somewhere.
Car: 82 Z28
Transmission: T400
Alright, this is probably going to sound pretty dumb, but how would I wire this to the relay?
Car: 82 Z28
Transmission: T400
When relay operates it sends power to fuel pump and to O2 sensor heating element
Typical GM pump relay wiring shown below
( confirm your actual configuration here
http://www.austinthirdgen.org/index.php?pid=19 )
Need to connect to terminal A on relay ,
might even consider installing a in-line fuse so you don't take out the main pump supply fuse. Engine will run without the heated sensor ; it won't if the pump won't run
Car: 80 TR7 V8 w/ 91 Z28 OBD1
Engine: 3.5 Liter
Axle/Gears: 3.45
This is an old post and doing some research ran into it.
Question on the 3 wire O2.
I want to install O2's on both sides so I can periodically check how the other bank is doing.
Will the heated O2 keep it clean while it is not being connected to the computer. I imagine the O2 doesn't know if it is connected or not so I can't imagine it matters.
Don
Don
well let me input my 2 cents. for one the heated 02 sensors do NOT DRAW A LOT OF POWER. and do not need a relay by themselves. they are low amperage. shorty headers are a thinner metal and dissapate heat a lot quicker than cast manifold. period! you can and will get an intermittant ses with shorties and a regular 02 sensor. and if you have a full flow exhaust with no emissions it will be sooner. rather be shorties or long tubes. a heated oxygen sensor heats faster and stays the same temp longer if not all the time. they work great. the one i used actually had 4 wires. 2 were ground, one hot and one ecm.
if you put one in on the other side the ecm would not know the difference unless they gave too many different readings which might throw an ses. but if you put onother one in and hooked to an air fuel ratio gauge it would not know the difference.
this is the one i am using.
http://www.summitracing.com/parts/CEI-103025/
Car: 1989 Pontiac Firebird
Engine: 305 Tbi w/lt4 hot cam
Axle/Gears: torsen 3.42
^^^^what he said.. headers give off heat, plus better flowing exhaust system and if you have a cam the overlap of air and unburned fuel cool down the exhaust. I was surprised how not so hot the exhaust is from the tail pipe. If thats not hot then the headers are not near 600+ degrees which they say is needed for the O2 to be fully functional.
They also don't pull crazy power like one92rs said..
I measured a 3 wire and 4 wire... the 3 wire pulled .600ma cool, as it warmed it dropped to .500ma the 4 wire pulled a little more close to 1A but it also heated up a little faster probably because they are used with OBDII which has tighter emissions. Also look at the factory wiring at cars with heated sensors its 18GA wire.. an inline fuse maybe 5A will be fine.
I did the mod a few weeks ago. it was a little bit of a pain running the wires for 12V and ground because the shorty headers are in the way and I don't want heat to damage the wires.. If I were to do it again I would do a 4 wire since your already under there running wires..
I got a three wire sensor and connector pigtail for the car side from rockauto, I spent less than $60 and it looks like factory.. well worth it since I swaped to a 95 truck pcm and they come with a 3 wire O2.
Its a nice change to see the O2 working on my af gauge when the car is luke warm a few minutes after startup and idle is a tad less rich and a bit more steady. Sorry for the long post but wanted to cover a few things.
Engine: 3.5 Liter
Axle/Gears: 3.45
More concerned with the O2 not reading correctly.
My car has long tube headers
Ignore the O2 with the purple wire. That is the one I have been using
With a multiport system, totally non stock.
I just want to make sure the O2 I am not using will function when I need it if I use the 3 wire system
On another Triumph I am building with TBI. Is there a problem if you run 3 wire O2's too close to the manifold?
in the picture it looks like the o2 sensor is in one of the primary tubes? wouldn't that hurt some of the flow through that exhaust port?
a 3 wire will work fine down further.. you can screw both in and heat both of them I don't see why that wouldn't work.. they will both wear out eventually connected to the computer or not.
Engine: 3.5 Liter
Axle/Gears: 3.45
Engine: 3.5 Liter
Axle/Gears: 3.45
That's why I plan on changing to the ones on the bottom.
I wish there was a way for the OBD 1 ecm to read both O2's
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I just ordered this heated 4 wire o2 from Summit. http://www.summitracing.com/parts/CEI-103025/?rtype=10 . I just want to confirm the wiring before it gets here. My only question is the 12 volt power supply feeding the o2. I see alot of ppl saying to grab switched 12v from the fuel pump relay. So I should just T wire in the O2 wire with the Tan/white tracer(A terminal on the Fuel pump relay)?????
Car: 89 Formula 350
sure it can get turn key 12v a number of ways. I was going to tap into the fuel pump relay circuit but I also have a few plugs from my smog/ac that I took out that has 12v with key forward
FormulasOnly
Sep 10, 2015 09:07 PM
