My front turn signal lights doesn't blink...???///??
Old Jun 2, 2011 | 09:53 PM
MrIrocZ28's Avatar
Why my front turn signals doen't blink, they stay lit, while the back lights blink? I've checked all my fuses, and I've changed the flasher.... What else can it be, should I change the silver fuses? HELP!!!!
Old Jun 20, 2011 | 01:23 AM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Re: My front turn signal lights doesn't blink...???///??
If I recall properly I had a similar problem with my car. My car has a history of sitting for years by the woods, so it had corrosion problems. I found some trouble and repaired it simply by cleaning up the wires grounded to the fender. Take the ground wires off the fender clean it up with a wire brush and return it. It fixed my problem.
Old Jun 20, 2011 | 03:13 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
check the grounds and the sockets themselves. then just verify that is the correct bulbs are in there spots. mine did that to, ended up being a bulb misplaced.
Old Jun 20, 2011 | 07:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Or a bulb with a broken element can make this happen - there are 2 elements in the turn signal bulbs.
Old Jun 21, 2011 | 01:02 AM
jeff_blake's Avatar
that is also true. forgot to mention that one.
Frozer!!!
Jan 19, 2024 04:55 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
