Fixed my fuel sending unit
Old Jun 2, 2011 | 09:57 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Like many of you, I experienced a gas level gauge that was constantly stuck on full. I happened to be dropping the tank to sump it, so I decided to investigate to see what was going on.
Unplugging the fuel pump and sending unit showed a full level on the gauge. Shorting the black to tan wire locations on the body side connector showed a level of empty so deduced that the wiring and gauge were good.
I then used a multimeter to ohm out the purple wire on the sending unit itself while moving the float up and down.... The multimeter read open circuit.
I priced some new sending units and they seemed to start at $188 which gave me some more motivation to try to figure out the problem.
I saw that the sending unit was held together by 3 tabs which were folded over, two on one side and one on the other. I pried back the one tab by itself and pulled the sending unit case apart.
Inside was a metal strip with many folded up contacts. The shaft that the floater was connected to had a spring loaded contact which touched the metal strip at different points depending on the level of fuel in the tank and the position of the floater.
What i discovered was twofold: first and most importantly, the metal strip had a tab connecting it to the sending unit case and on my unit, it was making insufficient contact to the strip, so i bent it down. After that, i put the unit back together only to find that the unit read full scale resistance no matter what the position of the floater.
I took the unit back apart, used a bit of sandpaper to clean the contact on the shaft, then bent the contractor a bit more to preload it against the strip, put it back together, and it worked!
Old Jun 3, 2011 | 10:11 AM
mrrman's Avatar
Re: Fixed my fuel sending unit
nice....this is my next task
Old Jun 4, 2011 | 08:13 PM
Andrew91GT's Avatar
Car: 1990 formula
Got the tank back in, put 5 gallons in the tank and the level on the gauge appears to be correct.
Old Oct 6, 2011 | 03:26 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Taking mine out tomorrow. Thanks.
Old Jan 21, 2015 | 08:59 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Is this fix still holding up? I'd much rather not buy a new sending unit, and my gauge reads just under half full with I fill it up completely…..
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
