Speedometer adjustment for new tires
Old Jun 7, 2011 | 11:50 AM
HitchDav's Avatar
Car: 1992 Firebird
Engine: 3.1 l V6
Transmission: Automatic
I am planning on getting larger tires come winter when I replace my old ones. I've got a 92 firebird and I want to know how to adjust the speedometer so that it is accurate. Do I need a whole new vss buffer box or can I fiddle with my current one to get the correct signal from it? I'm not talking about a huge change in size, but a 5% speed error is a bit more than I'd like to deal with.
Old Jun 7, 2011 | 12:11 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Speedometer adjustment for new tires
The driven gear can be easily changed whenever tire size or gear modifications are made. Once you have the correct replacement driven gear, simply remove the VSS and replace the gears. That's it.
Go to the TCI transmission's web site for further help with the correct driven gear combination.
Good luck
Old Jun 7, 2011 | 12:18 PM
HitchDav's Avatar
Car: 1992 Firebird
Engine: 3.1 l V6
Sorry, I'm still learning about these things. You can just change the gears for the electronic speedometers too? I had thought that only worked for the manual ones. I would not be surprised if I was wrong though. Thanks for your response.
Old Jun 7, 2011 | 12:22 PM
Wadebryant's Avatar
The (electronic) vehicle speed sensor in the transmission tail housing has a replaceable nylon driven gear. No messin with the speedo it'self needed.
Hope that helps
Old Jun 7, 2011 | 12:27 PM
HitchDav's Avatar
Car: 1992 Firebird
Engine: 3.1 l V6
Thanks a lot for the quick help.
Old Jun 8, 2011 | 08:56 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Wow - not sure I'd bother for the minimal change that different tires will make. Now the major differences with swapping rear gearing is worth the effort, but not tire changes (in my world).
86CamaroDan
Sep 29, 2015 10:08 PM
fasteddi
Sep 10, 2015 09:32 AM
Strick1
Sep 4, 2015 07:11 AM
andy74
Sep 3, 2015 08:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
