Taillight Info
Old Jun 12, 2011 | 07:44 PM
Johnnygeek's Avatar
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
Taillight Info
My car is 1988 formula an I would like to install 1990 TA tail lights
sorry for the large pics will figure out how to make a thumbnail.
ok so the back of the passenger lens side looks like
4 holes I think the inner one is reverse and the outer 3 are all tail+turn/brake?
My issue is My wiring looks like (drivers side)
and here is the old lens I will reuse 3 of the sockets and just need one for the turn/tail that I have cut off as they dont fit my new set
also I have read to splice a light blue wire from the brake switch and connect it to the white wire from the turn signal cluster that is coming down the steering column, so brake lights would use turn signal wire like hazards?
my main issue is would this not affect the front signals too? or are they separated in the turn cluster?
stolen web photo
any info will be welcomed
Old Jun 13, 2011 | 11:49 AM
Johnnygeek's Avatar
Car: 1988 Formula
Re: Taillight Info
strange only one lamp lights up and using turn feed for all 3 lamps on one side
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
