For a broke kid, this is an electrical nightmare
Old Jun 16, 2011 | 09:56 AM
Lamonaca92's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
How's it goin guys got a little problem with this. First my stop lights went out and then every time I popped in a new fuse, the fuse blew when I applied the brakes. I was told by someone to disconnect the defroster grid and that worked perfectly....for about 2 days. Now the problems back and I'm at a loss for ideas. Anything?
Old Jun 16, 2011 | 12:11 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: For a broke kid, this is an electrical nightmare
Sounds like it's time to start tracing down wiring. From your description you can keep on throwing fuses at it relentlessly, but you have a short somewhere that needs to be found. The back of the Haynes or Chilton Manuals have wiring diagrams which might help with tracing it down. With the brake pedal issue maybe it's the brake switch or something is grounding out your brake bulb wiring.
Old Jun 16, 2011 | 02:43 PM
Pocket's Avatar
Car: 91 Trans Am
http://www.austinthirdgen.org/index.php?pid=19
Use that and a multimeter. Good luck
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
gord327
Sep 29, 2015 10:18 PM
