weird electrical problem been hit front left side
Old Jun 16, 2011 | 10:11 PM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
i have an 82 trans am i was resently in a car crash nothing major just a fender bender hit an enbankment. fender was bent in pretty bad everything is working fine except for the front lights i figured its a bad ground but from what i saw everything is where it should be. the battery broke open and acid got on the iso relay for the headlamp motors i am replaacing that the next time i get a chance to get to the store. the wierd part is LH headlight works fine as far as driving lights go RH is very very dim as if i had saytime lights. LH motor did not go up unless i hit the turn signal switch twice as it seemed. RH only worked going down. i turn the switch on for the head lights and the marker lights go on with the headlights. the turnsignals dont work with the headlights on. on the dash when the headlights are on the two turn signal lights come on and stay on and are slightly dim. i took apart the bulkhead there was some gooy crap in there guessing electrical grease its everywhere on the the car where there are two connections. wiring harness seems fine replaced some lights and i didnt want to get to far into the dash and tear everything apart unless i have to if anyone has any sugestions they would be greatly appriciated considering i need turn signals and lights to pass inspection.
Old Jun 16, 2011 | 11:04 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Re: weird electrical problem been hit front left side
Check for any pinched wires under the damaged fender. I backed into my brother's stratus last winter in the exact same area and pinched some wires under the front fender. We played hell trying to figure out what was causing all the electrical issues..
Old Jun 17, 2011 | 12:27 AM
Car: 1982 Trans Am
Engine: LU5 CFI
yeah i know there wasnt any at least not at the fender, i took that off entirely trying to straighten it out a bit so i can get in and out of the car might be under the front bumper ill have to look tomorrow tho thanks
Old Jun 17, 2011 | 09:07 AM
19camaro83's Avatar
Hmmm.. has me stumped. Maybe when the battery exploded it damaged some of the electronics? I'm no expert, just throwing my $0.02 out there.
Old Jun 17, 2011 | 08:50 PM
Car: 1982 Trans Am
Engine: LU5 CFI
ok well managed to fix the turn signal and dim headlight problem just cant get the head lamps to work now, and the marker lights and headlights are both on when i turn the headlights on ha
db057
Aug 22, 2015 08:17 PM
kyleb24
Aug 15, 2015 08:24 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
