Check engine light
Old Jun 19, 2011 | 06:22 AM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
Check engine light
I get my check engine light that comes on intermittently. Anyone have any ideas where I should start checking? Oil and coolant levels are good. New air and PCV filters.....where do I look next?
Old Jun 19, 2011 | 09:20 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Check engine light
Why not check the code? Put a piece of wire connecting the A and B terminals on the under-dash connector, then turn the key on. Watch it flash a code 12 three times, then flash any other codes you have.
Old Jun 19, 2011 | 10:48 AM
Deck man's Avatar
Car: 91 RS
Engine: 5 liter
I've never looked to see if I had an under dash connector. I guess I assumed that since Auto Zone couldn't check anything older than a '96 that there wasn't one.
Old Jun 19, 2011 | 11:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Right above your knee on the lower dash when you're sitting in the driver's seat.
JamesC
Old Jun 20, 2011 | 07:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
https://www.thirdgen.org/service-eng...ht-error-codes
Old Jun 22, 2011 | 08:34 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
check and replace the engine!
Old Jun 22, 2011 | 09:54 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
on 90,91,&92 the connector is in a different location than 89 and earlier . it's located just to the right of the fuse panel . not a real easy location to get at . i bought an OBD1 code reader with a good manual on causes at advance a few years ago . it's much easier to use than the paper clip method . good luck .
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
