voltage decrease when car warms up
Old Jun 26, 2011 | 06:59 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
I have a 1992 Z28, with 5.7 TPI. When car starts voltage is great at about 14.5 volts, however when the car warms up, it steadily decreases, going all the way to 9-9.5 volts. It gets so low that car starts missfiring and sometimes dies. When I give it a little gas, it picks up a little, may be to 11 volts but no more. I read some of the posts mention bad ground connectors. Mine looks good. Is this simply a bad alternator issue? Thanks!
Old Jun 28, 2011 | 11:45 AM
robvano's Avatar
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
Re: voltage decrease when car warms up
Grounds are a good place to start. (Unfortunately looking at a ground will not tell whether or not there is connection between the mating surfaces). While the engine is off, with a good quality volt meter, check the voltage at the battery, take note of the voltage. Move the ground lead on the meter to clean metal on the engine block and/or chassis. These voltages should read the same within a ½ a volt. If not most likely there is ground problem, cause by ex: corrosion, loose connector, bad cable, ect.
If you find you have a good ground, then have the alternator checked it may have a blown regulator.
Good luck!
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
